medjoolguyExplorerDec 23, 2018Heat Pump(s) or control unitI have two 15,000 btu 48000 mach 15 heat pump / AC made by Coleman Mach. Both units put out cold air with no issues. My control panel allows the following choices a) heat / ac (gives you a range for...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentSway ControlA/C & Heat ControlHeating element?Water Pump Switch(s) Wiring guidanceOutdoor Griddle Heat Issue
