MrWizard
Dec 24, 2018Moderator
i'm not a heat pump expert
but
did you try heat & LP on either unit ?
did you try LP heat from furnace warm up the RV then switch to heat pump
what is the outside temp, 40* used to be the heatpump limit
but users on here say new models work to around 30* now
below their capacity limit you get not heat, since the unit is the roof or in the basement and sense ambient temperature , could be some will refuse to run in heat pump only mode
but
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
