dougrainer
Dec 25, 2018Nomad
From RVP
What is the temperature range for my Heat Pump?
The Coleman-Mach heat pump is an effective heat source, as long as outdoor temperatures are above 45°F. Below 45°F, there is not enough heat outside for the system to absorb, and efficiency drops. With a lack of heat, you will run into a freeze up situation that will shut down your compressor, but leave the indoor blower running. We recommend that, if you know your outdoor temperatures are going to be below 45°F, simply heat the application with the LP furnace until the conditions are more ideal for the heat pump.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
