DrewE
Feb 06, 2017Explorer III
Nicholsfamily05 wrote:
So after speaking to a different person at the dealership and exploring a bit the census is that they are feed off of the propane. Not what I wanted to find out as I don't want to burn through that much propane.
Yes it is a single 12 volt switch but they stated i have them on all 4 of my tanks.
Hm means I may have some work this spring / summer wrapping some pipe or putting in an electric blower with a heat element down there.
The tank heaters would not be run off of propane, obviously aside from the actual water heater (for the hot water taps). If there's a separate switch for holding or fresh water tank heaters, they'd be electric heating pads of some sort.
If the plumbing is in a heated basement area, that would typically be heated from the propane furnace.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
