opnspaces
Nov 20, 2013Navigator III
This is a weird problem in that removing the generator should have nothing to do with this. It's possible that the generator work is a coincidence. Are your 110v appliances and power outlets working? If so I would check the fuses at the breaker panel and see if any are blown. It's possible also that the charging part of the converter/charger went bad and is no longer charging the batteries.
Does the RV have a switch to draw off the house batteries to help start the engine? If so is that switch in the correct position to isolate the different batteries?
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
