BruceMc
Aug 18, 2016Explorer III
Do you have the integrated thermostat, similar to this one?
Single-Zone-LCD-Operation-Manual_17590.pdf
Mine has the same thing, and I encountered this issue too. Old-Biscuit has the right answer: The fan setting needs to be set to Auto.
Early one morning, I got up and turned on the heat, and the A/C fan kicked in! No heat (maybe), but a lot of constant noise. I finally turned off the A/C breaker to stop the fan.
Researching the issue after we got home, I found the fan setting was on something other than Auto. I'd probably tinkered with the thermo at one point before the trip as it is a new unit, and I'd never had an integrated thermostat before.
Hope this applies to yours as well.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
