Leonandlisa's avatar
Leonandlisa
Heater issue
I have a 2004 tailgater toyhauler, I did the digital thermostat conversion about a year ago and have had several trips without issues, this trip over New Years I had this issue, when I turned it on at night it would cycle 3-4 times (coming up to temp, cooling down and kick back on) and the the next time the thermostat would show that it was calling for heat but the furnace would not turn on. The first night I thought I ran out of propane so I switched tanks, the next night it did the same thing though with a full tank of propane. I found if I shut off the thermostat and then put it back on heat it would turn right back on. Again it would cycle 3-4 time the next hour or more and then not start again unless I shut it off and then turned it back on.
Not sure if this could be a thermostat issue or a heater issue, open to suggestions.
Thanks
  • Mine is powered by two AA batteries. If yours is as well then change those first. They are cheaper than a new T-stat and if that is not the problem you cna use the batteries in something else.
  • Leonandlisa wrote:
    I will pick up a new thermostat tomorrow, thanks for all the quick responses. Happy New Years!
    Heater comes on 3-4 times and then doesn't but does when you reset t-stat....sounds like t-stat works
    Sounds more like an intermittent power problem at/on circuit board.
    Pull connectors on board....clean contact surface on board with pencil eraser and check that connector goes on tight
  • I will pick up a new thermostat tomorrow, thanks for all the quick responses. Happy New Years!
  • Yeah,
    Start swapping parts until it starts working eh?
    LOL
  • Kinda sounds like a thermostat issue. Probably only way to tell is to replace it.
    That would be my first choice.
    Sometimes the only way to troubleshoot intermittent problems is by replacement.
  • Does it use its own battery? Maybe it just needs a new one to trigger its internal relay.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
