motc777 wrote:
dougrainer wrote:
Smell LP and hear Ignitor. Only thing to do is to pull the furnace and clean the burner and check the burner for mud nests. NO OTHER diag is needed until you pull the furnace. Doug
OK. The furnace is under a couch that I can lift up. Do I totally have to remove it from propane lines, etc, or can I just take the top cover off?
The COMPLETE furnace has to be removed. Disconnect the LP lines and the 4 wire 12 volt wires. Disconnect the duct plenums also and the outside vent. Once removed, you take certain panels loose to access various parts. WANT a BIG problem? Do it any other way and you will regret it. Doug
