motc777's avatar
motc777
Heater not working
We recently were having problems with the AC/Heater in the pull behind. It's a dometic thermostat, analog. We replaced it just a day or so ago. Fixed a lot of the problems, but one remains.
I switch to heater, and I go outside by the vent, and I can smell the propane and I can hear the igniter clicking, but it never catches fire. The blower runs fine.
What gives you think?
  • dougrainer wrote:
    Smell LP and hear Ignitor. Only thing to do is to pull the furnace and clean the burner and check the burner for mud nests. NO OTHER diag is needed until you pull the furnace. Doug
    OK. The furnace is under a couch that I can lift up. Do I totally have to remove it from propane lines, etc, or can I just take the top cover off?
  • Smell LP and hear Ignitor. Only thing to do is to pull the furnace and clean the burner and check the burner for mud nests. NO OTHER diag is needed until you pull the furnace. Doug
  • What is the make and model of the heater?
    Only way to correctly troubleshoot the problem.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
