Artum_Snowbird
Sep 12, 2015Explorer
First thing I would do is check for power at the A/C. Sounds like it's not there.
Next I might think of taking power to the A/C with a heavy duty extension cord just to see if it runs period. That proves a lot.
I would start at the breaker panel, and tighten both the hot wire on the breaker, and the neutral wire on the white connection buss. Do them all if you can, it's a good idea. Obviously, pull the power before doing that.
Heavy wires go to the A/C, then a lighter wire goes to the thermostat and comes back and picks up relays to permit motors to run. If you can troubleshoot electrically, it's just a matter of elimination to see what is wrong.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
