coryanderson's avatar
coryanderson
Repair help needed - Broken frame from dragging jack
I have a 2005 Eagle Cap 950 camper. I bought it just after Covid hit and took it on a 3 week trip and ended up at the first desert race since covid took a stranglehold of the world. I was trying to get a little further off the beaten path and after taking a long look at an entrance to a wash, I figured I could make it down safely and for some reason it felt like the truck took off in turbo mode and I went down to fast and I caught my right rear jack.
It tore the rear panel (with the door) backward 3-4 inches amongst other things. When I got it home I began to try to engineer a fix for it. I first took all the jack bolts out and then grabbed all of my large clamps and tried to clamp the back into place and then installed big lag bolts through the back panel. It fixed 95% of the issue on the back panel but we had another problem.
Click For Full-Size Image.
The door area also has a very large drop compared to the floor. When we use the jack it levels out. When we pull the slide out, you can see most of the floor area flexing a little bit when you don't have the jack down.
The camper has an aluminum frame and I'm sure it's snapped. I tried to build a support system underneath the whole camper but it was no where near strong enough to fix the damage that was done. I know it needs a huge tear down and repair. I have the tools and ability to do so, my main question is how do I even start...?
I don't know how to support it while I take it apart. I want to take the whole belly off and the rear 2 jacks and basically start over. I know I'll probably need to take the slide-out out. I think I'll end up replacing most of the passenger side walls and even perhaps the driver side.
Any advice or help is welcomed. I have gone through most of the rebuilds found on this website, however often times it's hard to tell how they support the camper while working on it, especially if I need to take the whole back of the camper off.
Thanks!
