firedoc
Aug 14, 2013Explorer
HELP Atwood automatic leveler - no power to control pad
Our 06 Bounder 38L has Atwood electric automatic levelers.
When we came back from the glass shop (had windshield replaced) and tried to set up there was no power to the control pad (buttons) as evidenced by inability to turn on (no lights). we are full timers and currently volunteering at a hatchery. Luckily our pad is almost level and requires no correction but walking around in an unstabilized coach is not to DW liking and therefore not to mine. Our next destination may not be so level! So I would like to get it fixed. Took control panel off the wall and found it just had one cable attached (4 wires) and they were still firmly attached. I removed and reattached them several times just in case of a poor connection. Nothing. There was no fuse on the control board and I cannot find a fuse in all the normal spots. I figure that the board has died,or a fuse somewhere has blown (for what reason?), or that there is a problem with one of the sensors (motor must be running,in neutral and emergency brake engaged in order for it to work). Any idea where I can start? Really don't want to take it to another shop $$$!
Thanks for any help
Terry
Thanks for any help
Terry
