MrWizard
Jul 12, 2015Moderator
sounds like the 12v DC auto reset breaker between the battery and the TT wiring is bad
follow the black wire from the tt battery, it should go to a little silver box with (2) connections on it , just so you know ..the Black wire is the Positive/plus and the white is the Negative/ground..do not hook up battery backwards
goto the auto parts store and get a NEW One size 40 amps
as a test you can move one wire from one terminal onto the other terminal , if the thermal breaker is bad and everything else is OK power will come back on
