Old-Biscuit
Jul 12, 2015Explorer III
DC circuit breaker
And if that isn't the problem......do you have a 'battery disconnect switch' turned OFF?
And if battery was ever hooked up backwards there are 'Reverse Polarity' Fuse(s) on converter that will blow
Any 1 of the 3 will not allow battery to supply trailer with DC power
Do you have a power tongue jack?
Does it work when trailer is not plugged into the Yukon?
