Samanthahhi
Jul 16, 2015Explorer
Turns out that my connectors were corroded AND the cut off switch was in the wrong position from what the rv dealership said it should be upon installation. But that would be secondary to the corrosion issue. The repairman did point our where the item you listed above was located. ..not under frame thank goodness. All is well!
