time2roll
Dec 29, 2016Nomad
45 amp is fine plugged in. On generator I would go at least 55 amps and right up to 80 amps would be great for fast bulk charging four batteries. However you need to review the charging circuit before you go above 45 amps. Common #10 or #8 wire is too small to go big on the converter. Even if the wire does not burn up the voltage drop will cripple the fast charging of any three stage converter. I recommend #4 wire with anything above 45 amps and possibly mounting the new converter close to the battery if possible. PD 9280 deck mount would work great.
www.bestconverter.com/PD-9280C-80-Amp-RV-Converter
Yes if you want the converter to fit in the existing position you may need to stick with 4645, 4655, 9260 converters.
Do not let Randy sell you a Boondocker unless you want a manually controlled unit.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
