Joel_T
Jan 06, 2017Explorer
BFL13 wrote:
If you are on shore power as it seems, then the converter will first run everything "12v" in the rig, and whatever amps are left over out of the 55 amps (simple explanation of voltage diffs etc) will go towards battery charging.
Hadn't really thought of the implications of that factor. Can converters only do their bulk and absorption modes properly if all 12volt drains are removed. Seems that amps irregularly lost to 12v draws would screw with any logic built in to the converter.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
