Joel_T
Jan 11, 2017Explorer
I have 2 260a 6v Crown batteries fed through a controller with 320w solar and when needed from 50 to 90 percent, through a WFCO8955 using a 2200w generator. While maybe a little short on amps and volts the PD4655V seems the most talked about upgrade. The 55amps may be all the 8 gauge wiring can handle, made worse by a 22ft run from the back of trailer to the front of the trailer, but the 14.4v is less than the recommended 14.8v to 15+ for charging. Am I overlooking a better converter charger upgrade. Remind me again what Vabs is.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
