time2roll
Jan 11, 2017Nomad
Joel,
4655 or even 4645 will run circles around the WFCO. PD is the best converter for smallish wire because you can force boost mode. With 22' of #8 consider a 9260 deck mount and use it as a portable charger.
Vabs = Absorption voltage. This is the voltage cap of the charging source that continues several hours before full charge and dropping the float.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
