full_mosey
Jan 12, 2017Explorer
nvreloader wrote:
Joem 789
Here is some info on the PD charger,
they have 4-different amp ratings, 45,60,70 and 80a,
my 4000w Gen set runs the 9260c OK.
IMHO, and with what little bit I know,
I would go with the biggest,
it is better to have too much and not need it,
(less gen set run time)
than have too little and need more etc.
I am sure the SOLAR Wolves here will correct me,
if I am wrong. ;)
http://www.progressivedyn.com/power_converters_9200.html
HTH,
Tia,
Don
You're right, I had to find something. :)
If you have 4 x 6V GC FLA batteries, even the 80A charger can be too small to minimize charge time.
Batteries can have an upper limit of charging Amps.
The maximum size charger would be the total of the upper limit charging Amps per battery as specified by the battery mfgr.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
