MrWizard
Aug 04, 2017Moderator
you can not check the ac voltage ?
or do you mean you can NOT check the A/C 'air conditioning ?
you changed an outlet, then plugged into 220v
you burned something
are your batteries charging ? do you have 12v for the fridge controls, for the thermostat controls
A/C and heater , and fridge, will not work with out 12v for the controls
you may have fried the converter ?
i know you are frustrated, but your posts are confusing
which makes it hard to understand what happen
do you have an on board generator, start it,
you may have fried the transfer switch
no generator you might not have an ATS (automatic transfer switch)
