MrWizard
Aug 05, 2017Moderator
MW does not run on DC
it might or might not be on the same output circuit of the inverter as say the TV etc.
that Freedom 10, is 1000w output (when inverter mode and has a 50amp max output for battery charging)
you blew the fuses , tripped the built in breakers, or Fried it
becuase it should be charging your batteries
you can test for the inverter function
unplug from shore power turn on the freedom from the control
usually an outlet in the kitchen with a switch on it
a little red light should come on
then plug in a lamp or anything that uses less than 1000w and see if it works
then turn off inverter plug into shore power and test again for 'pass thru' power from shore
you say all your outlets work, well some of them must be on the inverter like the TV or maybe a bathroom outlet or the kitchen outlet with the switch
my RV came with a freedom 10,
but 'I' fried the built in pass thru/transfer relay
{long story using another charger on the pass thru
too much load for faster charging}
