MrWizard
Aug 07, 2017Moderator
My 1995 DP came with a Freedom 10
And a MW that was 700w
So power went to the Transfer Switch > breaker box > then one circuit to Freedom > to four outlets
What ever body keeps calling the transfer switch, is the internal 'pass thru' relay
If you have 120v shore/generator it is allowed to pass thru to the outlets
If there is no power available and you turn on the INVERTER is use the battery to make 120v for that circuit
The Freedom is a combo unit, it is also the battery charger , 50 amp battery charge, when 120v power is available
There is no need for another converter charger, as is being mentioned in some posts, although i have never seen one wired in the manner the op is describing
I don't think He Will get any help from Xantrex , regarding parts and repair or wiring diagrams, i have searched the web, as have others
I think there is a guy in Arizona who repairs them, depending on the amount of damage
From the descriptions from the poster
I think his wiring is , shore power > TS
The Freedom > TS
TS > Breaker panel
In other words if power is available the Freedom is out of the circuit
But that means the Freedom would not be used for charging
If no shore power the freedom is the power source (if turned on)
Like others, i think the first owner, who worked for BF, modified the RV and installed the Freedom in that manner
The 220 may have fried the TS
The 110v the op is reading might be coming from the freedom using the batteries ? Which will soon be dead
Two big Red wires
Sounds like a fuse or circuit breaker from DC battery power to the inverter, Not 120v
These forums don't have picture uploading
You have to use another image host to store your pictures
Then put the image link in your post
Try tiny pic, or Google picture storage
Also one of our moderators set up a upload link and picture storage
But I'm on my tablet and don't have the link handy
Maybe somebody else can post it here for you
The Freedom > TS
TS > Breaker panel
Two big Red wires
