MrWizard
Aug 07, 2017Moderator
top off
looking from the front
the pass thru relay is left of center
the board is mounted vertical, the relay pokes out from the board ,
a plastic box with its top pointing to the rear of the inverter
NOTE
with no intervening external TS switch, the F-10 combo would be in charge mode anytime you has shore power (IF it is working)
for inverter mode you still have to use the inside control panel switch (if you have one)
or the Face mounted switch on the F-10 above the push button breakers
i'm thinking the 220 spiked the main control board and shut everything down
and will need repair
NOTE
