landlordy
Aug 07, 2017Explorer
I found on page 24 of the owners manual a description of the 3 transfer relays inside the freedom 10. They are mounted as you said to a vertical board but on the front right side of the unit. I can tell the 30amp push breaker goes right over there too. That board is the one w the tiny fuses that are still in tact. If this was as disastrous as it seems then those little fuses must be the toughest ones ever built lol. How can i test these relays? Do they need power to be tested?
