YC_1
Apr 29, 2013Nomad
If the merge switch allows the inverter to run and the engine batteries are 12 volts then the inverter is 12 volts. So measuring the voltage across the engine batteries is a way to work backwards towards the house batteries. I would run the model number of the inverter past the factory and find out if it is a 12 or 24 volt setup. Pictures of the battery banks would be helpful.
I would love to see a diagram of this setup if someone has one.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
