MtLaw's avatar
MtLaw
HELP!!! Coach batteries not recognized by inverter
We have an 85 Prevost which has had fairly substantial updates. Several years ago we had a new Magnum inverter/battery charger installed. The unit has a substantial set of house batteries which are all new. The coach also has a set of batteries (not new but good). The coach also has a generator which has its own battery for charging, which is also new. The coach has a 24 volt system and the house batteries are wired so as to deliver both 24 and 12 volts depending on the need. None of these thing have been modified recently.
The coach has 2 merge switches which 1. join the house batteries with the coach batteries and 2. join the house batteries with the generator start battery.
The house batteries were replaced this year. The guy who did it for me is very bright and handy and believes the coach worked properly after he was done w/ the new coach battery installation.
We took the bus out for a test weekend and found that the house batteries are not being recognized by the inverter. When we hit the merge switches the inverter kicks on, drawing from the starter batteries for the coach and the generator. However when the merge switches are flipped off, the remote controller for the Magnum says "low battery" and the inverter does not recognize the house batteries. The house batteries are fully charged.
We have spent 3 days trying to figure this out
Any ideas or suggestions would be greatly appreciated!!!!!!!!
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
