Sam_Spade
Jun 10, 2017Explorer
There actually are two or three possibilities here:
Converter went bad.
Batteries are getting REALLY weak, causing the converter to think they need the boost charge voltage all the time.
A loose or corroded main cable connection, also giving the converter a wrong signal.
P.S. How are you determining that percent of charge ?
Typically you can't trust a "battery monitor" for a real accurate report.
Converter went bad.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
