campingwiththor
Aug 05, 2018Explorer
UPDATE:
With the New remote- I plugged today directly into the logic board- the left side jacks work when connected. As previous- when plugged into the standard camper port none of the jacks work-
Does anyone think I might try removing the logic board at cleaning the connectors?
tks,
CWT
tks,
CWT
campingwiththoreau wrote:
2002 Bigfoot truck camper with HappiJac wired jacks and cable and remote. (the jacks are
replacements put on in 2014)
In the last couple years the remote would only work intermittently.
Now- won’t work at all (this is the remote with rj11 coiled cable)
When I plug in the cable- the remote starts green then goes to orange then off and
cycles like this only. There is some sort of power reaching the jacks because when I hit reset
you can hear the jacks make a noise for only a second… the other day even with
the issues described here the front left jack was working for a while.
Happijac sold me a replacement remote and cable. This new remote offers the same results.
Also- as per Happijac - I plugged my cable straight into the logic board. I get the
exact same results when I do this.
Im hoping someone here has an idea how I might trouble shoot this issue. Happijac wants
me to buy a new wireless setup- I am on a fixed income and really want to fix what I have.
Please help- will try anything. Because its intermittent and/or some sort of loose connection
or power issue…there should be a fix???
Regards,
CWT
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
