Boom's avatar
Boom
HELP!! Dometic CCC2 Issue
2014 Dutchmen Voltage 3990. 3 ac’s and my Dometic CCC2 is no longer showing
zone 1 anymore. The issue arose from having changed my fan motor out back in August, son comes up top to help and accidentally hits the dip switches and then threw an E1 code. We were actually camping and at a family reunion at the time and the front and rear ac were working so I said I’ll just deal with it later. I’m staying in it now for work out of town and a few weeks ago I read that if I disconnected all power it would reset and should fix the problem. Well I did that and when I plugged it back in and how well it worked, it took zone 1 completely off the thermostat with it only showing zones 2 & 3 now. I’ve tried everything, the unplugging all power to reset, tried holding the zone and mode button to reset, and then I even went and bought the circuit board that goes up top in the unit and replaced it and still cannot get zone 1 back up. I did the unplug all power reset initially because I learned that zone 1 also operates the heat which I have none of now and wish I hadn’t. I don’t think it’s a communication error anymore because that’s what the E1 code is because I put in a brand new circuit board and its operating zones 2 & 3. I truly am thinking it has something to do with the dip switches and I have searched relentlessly for how this particular setup should be set on the dip switches and don’t think I have found the accurate settings for it yet. If anyone could help or point me in the right direction I would be greatly appreciative!!!
1 Reply
  • If you have 3 roof units, then zone 1, there is NO DIP switch setting. The DIP switches are set for Zone 2 and Zone 3. Those DIP switches are set on The Zone 2 AC board and the Zone 3 AC board. You need to verify WHERE your tstat 12 volt power comes from. It can come from any of the 3 Zones at the upper control board. There will be a Black and Red low voltage wire at the connections for each AC unit. Only ONE of the 12 volts needs connected. The other 2 Zones get their 12 volt power from that one connection and also the wall CCC2. Usually, the Zones are set up FRONT of RV to Rear. Front is Zone 1, Middle is Zone 2 and Rear is Zone 3. But it appears yours was wired with the middle as Zone 1? NOT a big deal but can be confusing when trying to determine which AC is on what Zone. From your post it appears the middle is the Zone 1? Correct? Since the wall CCC is functioning that seems to indicate the middle Zone 1 is NOT the main controller AC. Either 2 or 3 is the controller. There is a COMM wire that looks like a phone cable that goes between all 3 AC units and then a cable from one of the units down to the wall CCC. Make sure the 4 wire connectors do not have ANY corrosion. Also, do you have Penguin model units? 600 series? Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
