newman_fulltime
Oct 08, 2014Explorer II
thats funny a tech is booked till feb he doesnt want the call.
if its a converter you need all it does is 12 volt an inverter takes 12 volt to 110.I dought you have a inverter in that trailer.
If it is set up for a generator more than likely the auto transformer switch
but if you do i would look at the batteries and make sure the reset button is pushed or the breakers on it are on.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
