Old-Biscuit
Oct 08, 2014Explorer III
How did you check the AC circuit breakers?
Just look at them to see if indicated tripped.........
OR
flipped them to OFF and then pressed hard back to ON position??????
Did you also check Circuit Breakers on the Inverter?
When connected to AC shore power your RV AC power comes fromshore power to the AC Panel (circuit breakers) and the out to various ac equipment/outlets via individual circuit breakers.
When not connected to shore power your RV AC power comes from battery via inverter which feeds AC Panel and then to various ac equipment/outlets.
If you are on shore power inverter just charges battery....it doesn't supply the AC power...only when not hooked up to shore power.
With voltmeter check for AC power coming into AC Panel.
OR
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
