MEXICOWANDERER
Oct 09, 2014Explorer
Westend, wrote the formula I would use. Tip, most inverters of that size use a DPDT PCB relay for power transfer. If the OP's system does NOT have a CONverter charging the batteries but relies instead 100% on the Freedom INverter to charge the batteries it means power is getting to inside the inverter. To make 12 volt charging power.
Does the OP's rig have an independent CONverter doing his battery charging work? Time to investigate.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
