BFL13
Jun 15, 2013Explorer II
Somebody on here has a Jayco and said the green wires were positive, with one going to the power centre (DC fuse panel and converter) with a 30a fuse, so the other is likely for the slide motor.(Lippert spec has a 30a fuse on our slide motor pos wire) (you already identified the jack one)
The 7-pin pos will merge with a pos wire somewhere on the way to the pos batt post
Hard to clean up wiring, but some use a buss bar approach to collect a bunch of wires and then just have one wire to the battery post.
If you get a Trimetric, you will have the shunt act as a buss bar, where one end goes to the battery neg post and the other end takes a bunch of neg wires.
Solar and an inverter add to the fun!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
