BFL13
Oct 25, 2015Explorer II
If the Stanley "recondition" is the same as the Vector's (sounds like it) you can run the R and charge at the same time. The R does not raise voltage.
In fact Mr Wiz has/had a charger that does R that you leave on all the time while the batteries are discharged and charged. He thought it did some good ISTR.
If you need to shut off the charger at 10a because the voltage might get too high overnight, you can still leave that R running no problem.
There is some controversy about the pulse type R's efficacy, but it can't hurt and might work, so why not?
You can restart the 10a first thing and keep an eye on voltage and SG now that it is moving up, or just return the Crowns and get the Trojans if that is what you really want, and they will let you.
Mena on here, has L-16s and has no trouble getting them to 100%, so it seems they are not "stubborn" like some batts are. They do need extra attention so they don't stratify, being so tall.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
