pianotuna wrote:
Keurig may require a pure sine wave inverter.
Do not know if Keurig needs a PSW/TSW or not.but so many things object to MSW that I would strongly recommend PSW/MSW,,VERY STRONGLY.
Oh,My Keurig (Mini-10) Works great on my Pure Sine Wave.
Difference between Shore Power,Generator power, MSW and PSW/TSW
Shore power is good and generally mostly clean
Generator power...Depends on the genny..Onan and other RV units are fairly clean, The INVERTER gennies ...see PSW/TSW... Some contractormodels..RUN they are that scary (Spikes into the hundreds of volt range can damage electronics)
MSW: the wave form is stepped, Like the Steps you sometimes see that enable a farmer to walk over a fence while keeping the animals penned.
Those steps are called a Stile. A pile of horse Dung is also called a Stile.. And that explains my opinion of MSW inverters (Dung).
Pure Sine Wave (Also inverter generators) That is the cleanest power your hardware will ever eat,,It is as sweet and clear as my Daughter's Flute (She is a professional musician among other things,and very good at it).
