pirlbeck's avatar
pirlbeck
Help me pick a MPPT solar charge controller.
A little background info.
This is for a truck camper with limited space. I would like to use the Lance factory 12ga solar wiring from the roof down to the charge controller. I can use larger wire/cable from the controller to the batteries, so that is not an issue. I really would like to avoid pulling or routing new, larger wiring from the roof down to the solar charge controller. I installed a Trimetric 2030 battery monitor and wired in a second battery that sits in the bed of the truck and pulling new wires/cables is not a lot of fun in a smaller truck camper like this 845. If possible, I would like to just plug into the Lance installed molded connector already on the roof, but if I have to remove the plug and install a roof junction box, it would not be a huge deal to me.
I do not feel we are large power user and I have large charge wires from the truck that charge the batteries pretty well when we travel. Last summer we took a 3 week trip and had not power issues, but we traveled a fair distance most days and had shore power most nights. This summer may be different as we are planning a trip to Alaska so we may be doing more boondocking.
Due to using the existing Lance wiring I would like to wire the panels in series and use a MPPT controller.
I have 2 Crown 31DC130 130AH batteries, new last spring.
I have 3 older, but unused Kyocera KT50 50Watt panels I picked up a year ago for almost nothing and I would like to use these panels. I may want to add more solar watts later IF roof space allows. I know adding more panels later and adding to a series string may be a problem as it may exceed the voltage limits of a lot of MPPT controllers.
Panel specs can be found here.
https://www.solarelectricsupply.com/kyocera-50-watt-solar-panel-kc50-308
Open circuit voltage 21.7
Vmp 17.4
Isc 3.31
Charge controller will be mounted in cabinet under the sink as that is where Lance has the solar wiring routed to, it is the only available location and it is close to the batteries.
I would like something that can be controlled and monitored with a Apple device (I phone or IPAD). I really do not want to wire and mount any sort of remote control/display panel. And changing settings and monitoring it without some sore of remote display is not really an option due to mounting location.
As far as cost......I don't want to spend more then is required, but I am willing to spend a little extra to get exactly what I want, if it is available. I would prefer it is something that has been available for a while and has a proven track record.
Thanks!
