Msu1976's avatar
Msu1976
Help needed with Honda EX-650 generator
Some time ago, I acquired a Honda ex650 generator that is in very good condition over all. I'd never had any need to use it until we had lost power in the house one day. My son was doing laundry, and was in need to finish drying his clothes so he could go to work. Thought I could help out by using the generator- for the first time. It started up great, and when I plugged in the dryer (it was connected to a heavy duty extension cord), the dryer almost immediately popped and began smoking. It had burned out. Out fuses and wires. I retried the generator on a few old junk electronics and received the same results. With that, I put the generator away until recently. I called Honda, the tech told me that if the generator had not been used for a while, it probably lost its magnetism and would require "Flashing". I've taken it to an authorized Honda dealer; and they told me (after $125.00 testing) that it would need a condenser. Also that a bulb would need to be replaced. Would a bad condenser cause these problems? He also mentioned a compacitor, but he may have mis spoke on that. They're stating this fix to cost $402.00 (includes the 125.00)! Hard to believe this, and hard to imagine that the generator would be worth that. Would appreciate any further advise, or expertise. Thanks
  • That generator is one of the extremely quiet ones. They were quieter than my EU2000i twins. That being said, they are only rated for 600 watts.
    Think crock pots, not clothes driers.
  • 2oldman wrote:
    I think you're a bit undereducated on what a generator is capable of running. A clothes dryer is a whopping big load.
    Sounds like it was pumping out TOO much voltage if it's burning things up. For curiosity's sake I'd start it up and put a voltmeter on it. Make sure the AC setting on the meter is around 500 volts.
    A condenser and a capacitor (not compacitor) are the same thing, according to my somewhat limited electronics education.
    Thanks 2oldman. You'd be correct regarding me being a "bit undereducated" regarding generators. Probably even more than that. Don't have a voltmeter; and never used one. Not a mechanical type of person. Was looking for some mechanical, repair type of advice. Would a defective condenser/capacitor cause those types issues or damage. Would the Honda representative be correct regarding the "Flashing", or are the Flashing issue and the condenser/capacitor issue the same. Because I probably will never use it, I was thinking about just getting it repaired, and then selling it. I understand that these were very nice little generators.
  • I think you're a bit undereducated on what a generator is capable of running. A clothes dryer is a whopping big load.
  • I would buy a new one also than invest that heavy into one so old
    It isn't ... rather than waste $$$ on attempting to repair this long out of production genset put it into a new one instead.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Jul 31, 2025
