dougrainer
Aug 28, 2016Nomad
You must have a hybrid system. HWH 2000 is air leveling only. Not familiar with a Air/Hydraulic 2000 system. HWH makes a Air/Hydraulic but it is not called the 2000 system. All you have to do is activate the Hydraulic motor and walk around the outside of the RV to determine its location and then the valves/solenoids will be on that pump. Here is the service manual for the 2000 system. Doug
http://www.hwhcorp.com/ml31043.pdf
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
