Chris_Bryant
Jul 25, 2017Explorer II
What the OP has is a relay- A is a common hot lug, that's hooked to the relay through a circuit breaker, which is mounted to the control post of the relay- used to be common, kind of wonky to me. C is the control lead from a switched ignition lead. The engine battery must be hooked to the alternator elsewhere.
