Old-Biscuit
Jul 11, 2015Explorer III
Your problem(s) are that you have a 1997 model WH and trying to replace it with a 2014 model.
They are NOT the same.
Atwood changed designs in 2004.
Previous used 120V AC directly to electric element via On/Off switch and set of t-stats on backside of WH tank.
The design change uses 12V DC for electric & propane operation via relay, a circuit board and 1 set of t-stats for both heat sources.
You will need a DC fused wire to a new ON/OFF switch (Dual switch with fault light is better change out than 2 separate switches)
Then that electric On/Off (White wire) thru circuit board will power a relay that is in electric cover on back of WH tank where element is. Relay triggers 120V AC to element
Propane is from DC fused wire to On/Off switch then thru circuit board (orange wire).
Blue wire is DC from circuit board to Fault Light in On/Off panel
Green is 12V DC (-)
New Dual On/Off Switch
New DC wire run for electric (white)
Old 120V AC wire to element
Old Brown wire for propane (orange)
Old Blue wire for Fault Light
Green is 12V DC (-)
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
