Golden_HVAC
Aug 16, 2015Explorer
The fan motor normally takes a 5 mfd capacitor. Even if you had a 3 or 4 or 7.5 MFD the 5 can replace it, and it will work.
The compressor can be anything from 35 to 50 Mfd. You what one of those to be 'close' to the right size, not off by more than about 5 mfd.
I have seen home capacitors in the 70 mfd range, but this one should be 35-50.
For a 120 volt compressor, a 370 volt rated capacitor is used.
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
