MFL
Sep 16, 2021Nomad II
I may be misunderstanding, but the main "VENTS" in the unit, I would take as the return vent also? Obviously, that will not work. The unit needs to breath, as it is a closed system. The fan can only push so much air through the small ducts. Are you sure your bedroom ducts have no blockage, or leak into the ceiling? I can notice a big difference in flow to my bedroom ducts, just by closing the direct quick dump on my 15K unit.
Jerry
Jerry
