Monkeyrun's avatar
Monkeyrun
Help understanding Allegro Furnace Operation
My Allegro BUS 39 is a 1999 model with a basement furnace. I started it up and found that it operates fine, however, understanding how it operates is a bit confusing to me. I posted several pictures in hopes that someone can help me understand it. The furnace sits in one area, what appears to be some kind of distribution box in another. The pictures became mixed up when I posted them so please forgive me if the descriptions are out of order relative to the pictures.
Hole in the floor behind couch. I believe there should be a register grate there but none found. One large heat discharge line laying in there and one small perhaps 1.5" flexible line in there which comes from the distribution manifold mounted under the stovetop.
An external fitting coming from the distribution manifold under the counter stovetop area. I did not notice any heat coming from this as I do the one mounted to the furnace door.
Another picture shows the external fitting coming from the distribution manifold under the counter stovetop area. I did not notice any heat coming from this as I do the one mounted to the furnace door.
Intake(?) and exhaust for the furnace which is below the floor as described above.
