Malster1's avatar
Malster1
Help upgrading to lp/electric heater 120 switch
I am upgrading my LP 6g water heater that doesn't work with a dual LP/Eletric heater from Atwood. The question/ issue I ran into is my 120 panel doesn't have room to add another breaker. I saw on a youtube video a rocker switch someone was using to switch between the microwave and the eletronic water heater. Basically, you can either have 120 going to microwave or the heater but not both.
Has anyone else done this or can help me figure out the correct switch to buy? I will already have the lighted LP/electronic switch (12v) for turning the heater on and off. Just need to supply the 120v.
Heard double pull/double throw and also 3 way on-off-on switch, but can't figure out which iOS the correct one.
Thank you in advance for your feedback and nay links that might help me.
  • Joe417 wrote:
    That sounds like a great idea. I need to implement something like that in our 5th W. That would stop a lot of running to reset the breaker. Still wouldn't stop it all as the wife has a hair dryer and electric skillet.
    I do a lot of electrical work and would go with a standard 3 way light switch simply because they are easy to find and cheap. Most are made for 15Amp. Not sure if they make a 20 amp version.
    I was wondering if a 3 way switch would work too. Any wiring drawings you could share? I'm pretty new to modding 120v. 12v i am good with.
    Thanks in advance.
  • That sounds like a great idea. I need to implement something like that in our 5th W. That would stop a lot of running to reset the breaker. Still wouldn't stop it all as the wife has a hair dryer and electric skillet.
    Any electrical/hardware store sells them.
  • Thanks, any links to where I can get one? My local big box Loses was clueless.
  • Double Pole, double throw
    Switch hot and neutral
    You 20 amp switch
    Be Very CAREFUL when wiring the switch
    Don't cross cross the hot and neutral wires at the switch
