TenOC
Aug 28, 2017Nomad
1. You will not be able to sell it for much with a hole in the wall. I would not buy it if it was "free".
2. Assuming you do NOT plan to travel in the RV, use it as a frame and cover the hole/walls with thin (luan) plywood or T111 outdoor siding.
3. coat the roof with liquid rubber or build a shed over the RV. The shed will keep the RV cooler in the summer and reduce any future leaks.
4. I other words turn it into a hunting cabin or "man cave".
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
