bondj007
May 02, 2016Explorer
when opened up for 4 or 5 minutes, hammering goes away. SHut off the last tap and the pump shuts off immediately. Perfect. However - Repeat opening another tap and within a short time - hammering comes back - open everything, let run, hammer goes away. Just noticed that through flex tubing, I can see a persistent stream of pea sized air bubbles on the outlet side of the pump. Not persistent on inlet side. ???
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
