Old-Biscuit
May 02, 2016Explorer III
Air is getting into system
Only place for air to get in is on the suction side of pump (discharge side of pump is pressurized and any 'opening' water would leak out vs air getting sucked in
Suction hose has a crack
Pump strainer has a crack or is not sealing around top/gasket
Pump inlet fitting cracked/sucking
Pump case is cracked
Winterizing valve/hose/connections are sucking air (if you have a winterizing kit on suction)
Air is getting sucked into suction side of pump..........
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
