Chris_Bryant
May 03, 2016Explorer II
The water heater acts as an accumulator in the system, whether you run the hot water or not. It is working the way it is supposed to- if there were no air cushion, the system pressure would rise enough to trip the PTR valve on the water heater every time you heated water.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
