Bobbo
May 04, 2016Explorer III
bondj007 wrote:
Hmmm - Good point, however the one thing that confuses me is the pump pressurizing delay also happens when just running cold water - ie nothing should be coming from hw tank but still takes 5 secs to pressure up when hw tank bypass is off. Why would this be?
There is no check valve on the cold water line going into the water heater. When you open a cold water faucet, the cold water line pressure drops, and the water heater pressure drops too.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
